One of the Common error for (Papper Jam) in printer is Error 0x000003eb.
Error code 0x000003eb indicated printer connectivity or printer installation error. If you are trying to install a printer driver but keep getting
Error 0x000003eb prompted, make sure you have logged in as the administrator of the computer and then try installing the driver. If the problem still happens, try the below solution steps to solve this problem. The error message doesn't give you much information as it just says unable to install the printer and gives you the error code 0x000003eb.
The Error Message shows you: "Unable to install a printer. Operation could not be completed (error 0x000003eb)"
The printer connectivity or installation error 0x000003eb occurs because the drivers are somehow got corrupted or incompatible.
We know the printer is a very important part of our day to day life. We all need a printer to get hard copies of our important files and documents within a few minutes.
ok. its vista. i did do a restart on the computer and its gives the same message on certain programs. this happened a few eeks ago and then the error stopped. now its back! thanks
hey-
i uninstalled and reinstalled the program. it still gives this error message! what should i do now?
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: DVD Shrink 3.2.exe
Application Version: 3.2.0.15
Application Timestamp: 4103f8b5
Hang Signature: d228
Hang Type: 16384
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Hang Signature 1: 58a7e021ea07d410176980b6b12d724b
Additional Hang Signature 2: 08c7
Additional Hang Signature 3: a499123f99ab86f43513a91a13ad2e9a
Additional Hang Signature 4: a69e
Additional Hang Signature 5: 6a3866c715ce7fc3e07f10c6390909dc
Additional Hang Signature 6: b90c
Additional Hang Signature 7: f406caeef6dd23b026bdf92ef20c7f16
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=5...
hey-
the apphang is happening again. last time i simply deleted the program dvdshrink and reinstalled it and it went away. now its happening again when i use dvd shrink, also sometimes when i use my ie7. I have vista home. here is the error I am getting- and Ive already unistalled and reinstalle ddvdshrink 2 times today trying to get the apphang error from happening!
Description:
Problem signature:
Hang Type: 16384
Locale ID: 1033
Additional Hang Signature 4: d7d5
Additional Hang Signature 5: 12c4b9e0d505da6a5db9fd4850578338
Additional Hang Signature 6: 0341
Additional Hang Signature 7: 46b854e89f8dde71ae43af20c68b9705
