Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
in the home screen double tap settings and scroll using three fingers and double tap general again scroll using three fingers double tap on accessibility and double tap voice over and double tap it to switch off
is it notifieing you that there is a lens eror? or does it just not turn on?
This type of problem you won't be able to fix yourself, and don't try to either!
You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
since you know where the fuses are, you also know where the flashers are. the flashers are the same part so unplug the one for the emergency flasher and put it into the socket for the turn signals and vice versa. if the signals now work but not the emergency flasher you know to get a new flasher unit at any parts store. the flasher units are cubes about an inch on each side plugged into the fuse panel.
