Televison & Video Logo
Posted on Jan 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV - Thin horizontal line picture on screen
We have just taken a TV out after having been boxed up for several months - the TV, not us. The sound is fine but the picture has reduced to a thin horizontal line approx 1 cm deep. The screen is black below this line. Above the line are thin horizontal "strands" spaced about 1-2 cm apart. To complicate matters, someone has lost the remote!
Diagnosis and options welcomed
Thank you,
Ian
Jay Henderson
Level 2:
Sergeant:
  • Expert 261 Answers
  • Posted on Jan 31, 2008
Jay Henderson
Expert
Level 2:
Sergeant:
Answers
261
Questions
7
Helped
106815
Points
522
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
  • Anonymous Aug 21, 2013
    i have same problem with kolin kct2570 horizontal problem, horizontal resistor r448 is burn can't be read. pls. give the exact value thx.
1helpful
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
1helpful
2answers
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
4helpful
3answers
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Solder bad connects in vertical circuit,especially vertical output
IC pins.................T.
PICTURE IS ONLY FINE HORIZONTAL LINE
Hi there,it looks as if you have a frame collaps,this is the first time i have ever heard of this on an LCD tv,i take it that there is no picture at all only a thin line.
1helpful
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
1helpful
3answers
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
