I was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tv
Instructions
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Locate
it.
Try
child lock code.
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted
trouble--if it gets accidentally turned on and you don't know the code,
you can find yourself unable to fully enjoy the full range of available
television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching
regular TV ....
do i have to go through the manufacturer
SAME THING
SAME SCENARIO--I DON'T HAVE A REMOTE AND THE CHILD LOCK GOT TURNED ON AND NEED TO KNOW HOW TO RESET IT OR WHAT I CAN DO.
magnavox 27MS343S 24" TV
child pressed lock on and i do not have the remote to turn it back on. What do i do?
Accidently turned on teh child lock, and I don't have the remote to fix it.
I was just flipping the channels and it just lock and i have a universal remote but it wont work to disable child lock wat do i do
APEX TV - in elderly mother's sitting room; she cannot see clearly and sometimes hits a combination of keys - TV is now locked; how do I unlock?
TV IS ON SOME KIND OF LOCK AND CANNOT TURN ON
Child Lock allows you to lock the buttons on the
front of the TV.
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- repeatedly until
SET is highlighted.
3 Press CH+ or CH- to highlight CHILD
LOCK.
4 Press VOL+ or VOL- to choose ON or
OFF.
Choose ON to disable all the buttons on
the front of the TV. CHILD LOCK ON
will appear briefly on the TV screen each
time you press a button on the front of
the TV.
You can still operate the TV with the
remote control.You can still use the
POWER button on the front of the TV,
but only to turn off the TV (not on).
Set CHILD LOCK to OFF to cancel this
feature so you can use the buttons on
the front of the TV again.
5 Press TV/AV/EXIT to remove the
menu from the screen.
In other words you need the remote.
I have a beatrix g-hanz tv that is blockedI can't find back the remote and manual, and due to a bad manipulation my tv's buttons don't work, the screen says "child lock" and i can't find how to display this child lock... maybe a button combinated with off/on but... please help!!!
Not no key is in function because of that child locd
What should I do
