My sony erricson k810i camera setting button is not working when i open camera message is showing pleae insert memory stick or select save to phone in camera settings
Hi the first thing you do to format your memory stick is you need to
Insert the memory stick on the camera because it is formatted in the
camera.On the camera,you need to turn the MODE DIAL to the SETUP position.And then turn on the camera. By using the CONTROL BUTTON, kindly press the DOWN ARROW button to select MEMORY STICK TOOL.And press the center of the CONTROL BUTTON.Kindly press the UP ARROW or DOWN ARROW button to select FORMAT.After that press the RIGHT ARROW button.Kindly press the UP ARROW or DOWN ARROW button to select OK and press the center of the CONTROL BUTTON.
Hopefully those instructions will help you get going again with your Sony digital camera. Good luck!
Right reset your phone. Connect to a computer, click file transfer. take the phone out, this automatically resets it. After youre phone should work with camera, remember take one picture, if you dont then it wont work again. Same problem with me, and i fixed it.
To run Settings download: Press menu on fone Go to Settings,,..then Setup Wizzard then Settings Download then press select this should then contact the provider for settings for fone ;-)
remove the memory card and erase the Gold colour metal edges with Pencil Erase ( rubber) make it shine gold like new and place the DUO card it should work
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
