The easiest way I have found to do this is us some Emery cloth or fine grit sand paper and sand down the shaft real good. Then spray the shaft with wd40 or other penetrating oil and use a crescent wrench and close it around the shaft to keep the shaft from spinning and turn the fan blade while gently lifting.
Hi.
Trying applying some heat to it wiyh a hair dryer or similar, then spray it with WD40 or some other kind of penetrating oil.
I am assuming that you are in the USA, as this is not a make of oven I have heard of, and I live in the U/K.
If you have not already removed the nut that holds the fan on, then do not try to unscrew it the conventional way, because if it is the same as british ovens, then the securing nut is a left hand thread, this means that to unscrew it, you turn it clockwise, as thiugh you were tightening it.
I hope this is of some help to you.
Happy new year.
Honest opinion is to just buy a new fan. BUT there are a few options to reomve it.....
1. cut the shaft and try to drive it out. 80% chance of no damage.
2. go buy a puller and remove it with it. A ok puller from a auto parts store 20 bucks. rental 5 bucks. Damage 95% no damage.
3. all the time to chase parts and gas. 20 bucks.
Hopefully you can get it removed from the shaft from the fan. Best of luck.
LOL good luck if your not willing to take advise. what do you want someone to go to your house and remove it for you? My suggestions are tried and true. Just buy a new one.
Your statement:
problem is i need to remove motor from oven it seems you have to remove fan first i am unable to loosen screws holding fan onto motor shaft also if i did manage to loosen screws the shaft has a keyway i need to remove motor with fan attached not sure how to do this
How in the hell do you get seized on your original question?? If you would of asked that before my answer would of been competly differnt. But instead of asking a clear and competent question you give only a small portion of the requiered info that we ask experts need to properly ask a question. Then you give bad ratings.
Ok I will continue to try and help. Here are my questions and help for you. Once again I know if you follow it they will fix your question you asked.
1. Are the screws stripped by you not having the proper tool or access? Always use the proper size screw driver to prevent stripping it.
2. Have you opened the acess panel to the fan itself?
3. The key in the fan will allow you to just slide it out. there is a allen screw on the key or shat that helps hold the fan. Once more if the fan has a .0002" interference fit you will need a puller.
4. Once the fan itself is removed from the acess cover. Unbolt the bolts mounting the motor in the oven remove the motor. It will need to be removed (fan) in the oven to do the work requied to complet the job you are trying to do.
HOW TO REMOVE MOTOR WITH FAN ATTACHED
