An electrical supply house would have, or could get your fuse. You can also contact Dream Maker and they would send one to you. It sounds like the you have a voltage issue and may pertain to other fixtures you have on the circuit (such as freezers). If you have the spa plugged into an extension cord, this will likely be the cause. You need to have an electrician run a dedicated 15 amp service to the spa.
5amp 250 volt...there are many different ones... take old one to lowes or home depot...possibly walmart.
It requires a 20amp 250volt fuse. If you have a 5amp then that’s why it’s blowing.
