Due to electrical problems we have had to replace the control board in our washer. We get an error message: Pressure sensor not communicating with control board. According to the manual, we need to to replace the control board. We've just put in 2 brand new ones - big control board and the little one to the left. Any ideas where to go from here?
Thanks!!!
I agree with the pressure switch could have been this in the first place? But also when you replace the boards they may need an eeprom program as they may be a blank un programed board
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
Hello Elizabeth - Typically error code E31 indicates that the pressure sensor is not communicating with the main control board. I would suggest contacting a professional to inspect the wiring between both parts. Depending if the wiring is defective or correct might have to replace the pressure sensor. If it does not correct the problem, the unit may possibly have a defective control board and will need replacing.
Hello Lance - Error code 32 for Frigidaire models means there is pressure sensor calibration problem. This will need to be checked and a repair performed by a technician since they must do the following: inspect the wiring between the pressure sensor and the main control board. Correct the defective wiring and/or replace the pressure sensor or main control board.
