Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso Ld error code
OK Iv done everything you posted here http://www.fixya.com/support/t3398539-ld_display
except....
" Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test."
Is there any other suggestions besides this?
6ya staff
SOURCE:
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: washer gets ld code
The ld fault is a long drain error. Check your drain pump reservoir and drain hoses for clogs. Removing the agitator in my opinion would be unnecessary. Unplug your machine and remove the back panel. There should be a drain pump reservoir at the bottom under the wash basin. They are notorious for collecting lint and hair and can obstruct the drain flow. You can also squeeze along the drain lines and feel for obstructions. To access the drain pump itself, its easier to remove the front panel. You will need to release the two metal hold down clips located under the front lip approx. two inches from either side. You need a putty knife to push in on the clips and lift on the top front at the same time. Once you have the top released, lift up and remove two screws holding the front panel. The front panel should pull away leaving an open access to the inside cabinet. The drain pump is located on the lower right-hand side of the wash tub at the very bottom of the unit. You can easily remove the two drain lines at the pump and check for obstructions there as well. Again, unplug the unit before servicing the pump. I hope this helps.
Posted on May 04, 2007
Anonymous
SOURCE: What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Posted on Sep 02, 2008
Anonymous
SOURCE: Kenmore Calypso washer Ld code?
I recently had the same problem. I actually took the two hoses off of the pump and found a penny in their. It was actually difficult, I couldn't figure out an easy way to get the water out first and had quite a mess. But now the washer works again.
Posted on Feb 22, 2009
Anonymous
  • 102 Answers
SOURCE: what does LD and OB mean on my washer
LD means long drain and will require a pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out. I don't know what the other code means but most of the time the pump is the major problem with these units.
Posted on Apr 06, 2009
Anonymous
  • 32 Answers
SOURCE: calypso washer gives error code Ld or ob. won't
Ld=Long drain. If it takes longer than five minutes to drain the water the operating pressure switch resets. Most common problem associated with this code is a clogged or failing water pump and hoses.
ob=Off balance. Open the lid and redistribute the clothes evenly around the tub, close lid and press the start button.
Posted on Jul 25, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso flashes ld code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
https://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Calypso GVW9959K flashes ob, sl, and ld. now i figurd out that the drain pump was bad but should i buy a replacement or will it still flash ob and sl if i do?
Nov 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
554 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
