Linksys WRT160N Wireless Router  Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get the Linksys Router's list of Network Security Settings
I have obtained the following information before, but do not remember how to get it. How do I get a listing (printout) of the Linksys WRT160N Router's "Network Security Settings" ?
This is a brief list composed of the following information.
Network Security Settings:
router username:
router password:
network name (SSID):
network security type:
network security key connection type:
Thank you
DaleB
  • dale_brandt Jan 02, 2010
    Hi:
    Thank you for the information.
    It is useful, but does not answwr my specific question, which may need to be restated to clarify, so here goes.
    The Linksys WRT160N wireless router uses CISCO's Network Magic software to allow the user to monitor & maintain their connections. During setup, "somewhere" Network Magic stores the Network Security Settings and allows the user to print them out and save them to a file. The entire file printout is as follows (see below), along with specific settings for each parametr.
    My questions is: How do I reproduce this exact printout with aall of its information? I did not have to "play around" inside of Linksys's 192.168.1.1 web page in order to make this printout - it was done from within Network Magic, and I haven't found all of these parameters in aa grouped list within 192.168.1.1.
    Thank you (see list below)
    router username: admin
    router password: ElasRouter
    network name (SSID): ElasWirelessNet
    network security type: Higher Security (WPA / WPA2)
    network security key: FredDale
    connection type: Keep Alive
  • Anonymous Apr 27, 2013
    if you have made any progress on this issue please post an update, i have *exactly* the same question and want to save *exactly* the same information, at some point i'll need to reset my router and try to reproduce the file...
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jan 01, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557472
Points
31058
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Testimonial: "Need more info...Thank you."
  • Anonymous Jan 02, 2010
    On your computer:
    Click Start
    Click Run
    Type CMD and press ENTER
    Type IPCONFIG and press ENTER
    Look for a line like:
    Default Gateway . . . . . . . . . : 192.168.123.1
    Start Internet Explorer
    Type http://192.168.123.1
    to access the router's built-in web-server, and "browse" around to find the settings.
Prashant M
Level 3:
  • Linksys Master 2,278 Answers
  • Posted on Mar 13, 2010
Prashant M
Linksys Master
Level 3:
Answers
2278
Questions
Helped
978503
Points
6246
You will need to check the wireless settings of
the router.
If your network is secured then make sure that you
are typing the correct network key.
also make sure that the DHCP server is enabled on
the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
Click here for step by step instructions
2answers
How to create a password for the linksys router
Linksys WRT54G Setup
li {margin-bottom: 10px;} Linksys WRT54G Wireless-G Broadband Router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
  2. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  3. You should see the Setup page shown below.
    Accessing the router settings through a web browser.
  4. On this screen you should change the Router Name from its default value to something unique so that your Base Station will not be confused with another. Scroll to the bottom of the page and click Save Settings then click Continue when the Settings are successful dialog is displayed.
  5. Next, click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use the same name you set as your Router Name in the previous step. Then Disable the Wireless SSID Broadcast option and click Save Settings and then Continue when the Settings are successful dialog is displayed.
  6. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
  7. Next click on the Wireless MAC Filter subsection at the top of the page. Then Enable the Wireless MAC Filter option and select the option to Permit only PCs listed to access the wireless network. Click on the Save Settings button at the bottom of the Filter List window and then Continue.
  8. Now click on the Edit MAC Filter List button to pop up a new window (shown below) where you will enter the MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed. You may now close the Mac Address Filter List window.
    Creating a MAC Address Filter List will prevent unauthorized computers from using your connection.
  9. Finally click on the Administration tab at the top of the page. Change the default password for accessing your wireless router setup pages by typing a new one into the Router Password field and then confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed.
  10. If you encountered any problems during this configuration procedure, please consult the manual that was included with your router or contact the manufacturer.
  11. Your Linksys Wireless Router is now secure
Cant seem to connect to WFC for a dsi game
Hi gabrielsa544,
Welcome to Fixya. Nintendo Dsi/DS/Ds XL connects to the internet using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
How to access the Router:
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab check you Network Name or SSID. On the Security Mode you can check the security if you're using either WEP or WPA. Then you need to remember the Netowrk Key you can also personalize your Network Key. The Network Key serves as a password on your network to make it secure. Then Save the settings
Take Note of the SSID and the Network Key
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection
Thanks for using Fixya.
2answers
Lost security code for wireless linksys router
Hi alockklock2,
If you want to obtain the password or security on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure.
You can also reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
If this works dont forget to say thanks. Thanks for using Fixya.
2helpful
3answers
Can I retrieve the current password for my linksys compact wireless G router without affecting the other computers on the network?
In order to find the wireless security password of your Linksys wireless
follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.1.1 and hit enter.
2. You will be logged into the Linksys router setup page .
3. In router's setup page, "username" is always blank. If you have set the password, type the password. The default password for linksys setup page is "admin".
4. There under the wireless settings you will find the security password to connect the wireless computer.
Good Luck!
Thanks in Advance!
With Regards,
How do i setup my wireless linksys model wcg200?
The wireless settings that you need to take note of are:
a. SSID - this is the name of your wireless network
b. SSID Broadcast - an indication if your SSID is showing on the list of networks available
c. Wireless Security - serves as the password for your wireless network
To check the wireless settings on the Linksys router, follow the steps below.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router's web-based setup page. For instructions, click here. If you are using a Mac computer to access the web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless.
4678-009.png Step 3:
Look for Wireless Network Name (SSID). If it's still set to "linksys", change it to something unique then click 6-4680.jpg NOTE: Take note if SSID Broadcast is Enabled or Disabled. If it is Enabled, it means your SSID will show among the list of wireless networks available when any wireless device will search for a network to connect to. If it is Disabled, it will not be visible.
Step 4:
Click the Wireless Security subtab and take note of the current Security Mode.
If Security Mode is set to WEP:
4678-007.png If Security Mode is set to WPA:
4678-013.png You can change your WPA shared key if you want to personalize it. It should be a minimum of eight and a maximum of 63 characters long.
Step 5:
If you need more help come back.Post / thumbs / testimonial are welcome!
Can not connect to network
Connecting to a Wireless Network Using Linksys Wireless Manager Article ID: 17673
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
2answers
How to secure my internet connection?
SETTING UP WIRELESS SECURITY ON YOUR ROUTER--------
1> connect your PC with the WRT54G at port no. 1 through wire and check for the light status of the router to ensure that it is connected.
2> access the router setup from a web browser (may be using 192.168.1.1, the default address of your router, and admin as the password.).
3> at the top click on wireless on the BLACK bar at the top.
4> under wireless click on wireless security on the blue bar.
5> select the security mode as WPA-PERSONAL (best encryption and supported by all devices).
6> select WPA ALGORITHUM as TKIP.
7> in WPA Shared Key type: "superman" or any thing else but it should be at least 8 characters long. and you should remember it as this will be your wireless password.
8> the Group Renewal key should be 3600.
9> Click on save settings at the bottom.
PERSONALIZING YOUR WIRELESS NETWORK NAME--------
1> Under Wireless, click on Basic wireless settings.
2> MODE: mixed
3> NAME: <WHAT EVER U WANT> CHANGE IT eg NINJA, SPIDER etc
4> Channel: 11
5> SSID BROADCAST: ENABLED
NOW YOUR ROUTER IS CONFIGURED.
Also Check out the following:
http://technicallyeasy.net/2009/02/securing-the-linksys-wrt54gl-wireless-router/
http://www.howtodothings.com/computers-internet/how-to-protect-a-linksys-wrt54g-router-using-wap-and-wep
6helpful
I am trying to connect a new kindle to my existing wi fi (cisco linksys) but cannot remember the password I entered for my linksys.
I think you meant the access key password for your wireless security and not the password for the router itself (2 separate passwords).
I'll give you both solutions starting with the wireless key password.
1. access the router configuration page by typing http://192.168.1.1 in your browsr. 2. This should pop up a log in window asking for user name & password 3. The default settings for a linksys router say to leave the username blank and type admin for the password. 4. once you're in look for the Wireless tab and click it then click on wireless security 5. your password will be listed there in the shared key box.
Now if its your router access password that you need you'll need to reset the router if you can't remember it and then follow the steps above to create a wireless security password. Here's how you reset the router. Remember that all custom settings you may have set will be erased and the router will go back to original factory configuration settings
1. On the back of the router you'll find a small hole or indentation and it may or may not have the word reset printed by it. 2. Find a paper clip or something of the same size and use it to press the reset button for about 2-3 seconds 3. Router will be reset
Good luck
I can't remember the security key code. Can I
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Will not connect to internet. no drivers in computer
The WRT54GS router from Linksys is a wireless-G broadband router. This router lets the user access the Internet through a wireless connection as well as use it to share resources among computers on the network. The Linksys WRT54GS comes with a CD-ROM, which will run a Setup Wizard to walk you through configuring your router. Without the CD-ROM, configuration can be done through the router's web-based utility.
  1. p 1 Launch your web browser, then type 192.168.1.1 in the address field. Press "Enter". On the password screen, leave the user name blank. Use admin for the password. Click "OK".
  2. Step 2 Select the appropriate Internet setup settings in the Setup>Basic screen. Many of these settings are obtained from your Internet Servicemag-glass_10x10.gif Prvider (ISP). Other than the settings obtained from your ISP, the default settings should work for most network applications. Set the time zone in the "Time Zone" field. Click "Save Changes" before navigating away from this screen.
  3. Step 3 Select the appropriate wireless standard from the drop down menu in Setup>Basic Wireless Settings. If in doubt as to your wireless standard, leave the default selection at "Mixed'. This will work for most network applications. Type a name for the Wireless Networkmag-glass_10x10.gif Name. This name must be identical for all wireless devices on the network. Click "Save Settings" before navigating away from this screen.
  4. Step 4 Select the appropriate security method for your wireless network in the "Wireless>Wireless Securitymag-glass_10x10.gif" screen. If you do not wish to utilize security, leave the default setting of "Disabled". It is recommended to use some form of security for your wireless network. Whether you use WPA or WEP security, all devices on your wireless network must use the same encryption method and encryption key. Click "Save Settings" before navigating away from this screen.
  5. Step 5 Reboot the router so all the changes take effect.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
