This relatively new fridge worked fine yesterday morning but by noon it had no power, no light,no compressor, no nothing the wall plug is good and has power.
i don't know how old your fridge is but on older ge's if the evap fan motor was bad they wanted you to also change out the motor board.first thing unplug it,look at the board the newest boards have 7 relays on them,if yours doesn't i would change the board out,this is what powers everything in this machine,compressor,fans everything,so if i had this issue i would change out the board or it sounds like you could have a bad compressor but that would be new fridge time, part wr55x10942 now the newest board is wr55x10942p i haven't seen one of those yet but i looked up a fridge yesterday and saw that so they made more changes to this board.good luck
If there is no heating it is possible that the MAGNETRON has failed provided there is supply feed to the unit when the microwave is powered. Normally the magnetron along with the fan and light comes on when the microwave power is triggered. So since the rotation is absent it is possible that there is no power feed from the processor board which can be related to a driver failure. You need to check the output from the PROCESSOR to confirm and pinpoint the defective component. Check the relay to the magnetron trigger as this can be a suspect.
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
its located on the botom of car . inbetween the radiator and the motor more towards the driverside (middle area) u should see the transmsission when your down thair. its conected to it . looks like a cylinder
Check the breaker pannel or fuse box. The elements work on 220 volts the lights on 120 volts. If this doesn't help repost and well try again
Hope This helps
Please leave feed back
Sounds like water damage. Are there any red stickers under the battery? If so, then it is water damaged.
Either way, if you are the primary line then Verizon may offer you an early upgrade if your rateplan is above a certain price point (if that's who your on). If not, you can do an insurance claim, if you don't have insurance then you will have to either pay full price for a new one, or purchased a used one.
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
