Samsung BlackJack Logo
Posted on Dec 31, 2009
It's locked in airplane mode - Samsung BlackJack
I have a Samsung Galaxy J3..I was wondering if there is a way to remove the "turn on airplane mode" verification, so to turn on my airplane mode, all I'd have to do is click on the Airplane mode icon..
No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
1helpful
Irola tablet stuck in airplane mode.can't turn off airplane mode
You have to do a hard reset its not seing your sim card ask me how if you don't know how
Jan 29, 2016 • Cell Phones
2answers
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
Nokia2760 no network
Go into your settings and put your phone into airplane mode for ten seconds, then turn airplane mode back off.
If this does not work do a hard reset on your device by pressing and holding the lock screen/power button.
Thanks,
Dish Guy
2answers
Unable to acces network
Perform a hard reset on your device by pressing and holding your lock screen/power button until your device powers off. If this doesn't solve your problem please set your phone to airplane mode for ten seconds, and then turn it he airplane mode back off. Airplane mode can be accessed through your cell phones settings.
Thanks,
Dish Guy
2helpful
3answers
I have droid phone. Says on airplane mode. How do I turn airplane mode off?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
9helpful
3answers
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
I have locked my phone
change the profile on General or something else...that should deactivate the airplane mode. or tell me what do you mean by Locked..
Oct 28, 2009 • LG RD2030
Txt n on the iphone
it's a workaround, but it works if you're going to leave your phone unattended...
First, go to Settings > General > Passcode Lock Turn the passcode on and create a password to protect your phone--set this to the time you prefer for your phone to go into locked mode.
Next, under the same Passcode Lock screen, set the "Show SMS Preview" to off.
Lastly, when you're going to be away from your phone, set the phone to Airplane Mode under general settings.  By setting to airplane mode, you won't get any new information pushed to you.
If you're not in airplane mode, it will still show on your home screen that you received a text message from a specific number but it won't preview the message. In order to retrieve the message you will have to go into the sms function, which will require that you enter your passcode.
It's not perfect and it requires you to think about it, but it will work for you.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
