If you don't use it (press a button, take a pic., take a video, etc.) then it will turn off because say you put it in the case and forgot to turn it off, then it won't stay on and waste the battery.
I have that problem with my camera too but after a while... I gave up retype-ing the date and time, so know every picture is on Jan.1st 2004 at 00:00:00 :D I have tried as many things as I could TO fix it but.. nothing came through...
I looked at all the settings that you are able to change on MY camera and no.... you can't.... I was wondering that too a while back and I had to just give up on that.... :D hahaha.... but I hope this helped....
pls download the manual, memory card , compatability is a problem . panasonic,scandisk,toshiba only will work. if you put other m cards , the picture will be very bright-negative effect
there isn't a night vision mode i don't think... I've had this camera for a while and i havn't been able to find it.... BUT .... I did find something else that you could use sometime...
1)click the MENU button (M)
2) click left 3 times
3) then you have options for auto, daylight, cloudy, tungsten, and fluorescent.
sorry I could help you with your origional problem but at least now you can change some settings. :D
Will the camera work without this item set up or does it stall there?
If it works otherwise, just live with it.
There is not a 'repair option as such-
you could check out the Polaroid Web site tech support team though
When power on the camara after 2 min. power is power is off. kindly give me solution .
camara s/n E0700131120057085.
Regards
Rishi khanna
