Please advise me on following problem.
My Nokia 6630 is always trying to access web even the phone is in switched off mode or in switch on. The battery is getting down fast and i am not able to use the phone properly as whenever trying to open menu, in between it is showing the blank screen with written web on the left top corner. pls help
Pls let me know how to lacate internet browsing in Nokia 6630 to manually turn off the WAP service/ ThanksPls let me know how to lacate internet browsing in Nokia 6630 to manually turn off the WAP service/ Thanks
You can't post conmments that contain an email address.
Hi!
may be you do not close web and just switch to oher applications. this cause the current open application to run in background which consumes bettery! make sure to close applications properly.here is the tip "press and hold menu button, it will show list of opened application on top left of the screen, goto those applications and close them"
hope it will work!
1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# or *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message 'Format it
hi..please follow these steps..in order to unlock your phone..
Warning: Do not enter any wrong unlock unlock codes on your Nokia 6630 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6630 without any sim card. 2 - Don't bother as to what is displayed on your Nokia 6630. 3 - Compose #pw+CODE+1#. 4 - The Nokia 6630 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6630 mobile phones locked to the network Fido or Rogers in Canada follow these instructions : 1 - Switch on your Nokia 6630 without any sim card. 2 - Don't bother as to what is displayed on your Nokia 6630. 3 - Compose #pw+CODE+7#. 4 - The Nokia 6630 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly The letter w appears if you press the button star(*) four times quickly The symbol + appears if you press the button star(*) two times quickly The CODE you need to enter is the unique unlock code for your Nokia 6630 thank you very much..i hope this'll help..
sounds like you've ot a dodgy phone or battery. Does the new battery have the new Nokia hologram on it? If not then it's probably a cheap far-eastern knock-off.
Also, you can switch off 3G access (depending on the firmware in your phone, has to be a couple of versions old or newer). Being connected to 3G drains your battery hard.
Go to Menu > Tools > Settings > Network, and the first option should be Network Mode. Switch that to GSM, reboot the phone and it will not search for WCDMA access anymore.
Turn off ur device. Press 3 buttons, Green (Call), * , and 3
Simultaneously and then Switch on the Device holding the 3 buttons
still. . .dont leave it for 3 mins or so. Without MMC
i too have the sam problem with my nokia 6630 . its not a good cell phone i have to say . the problem u said is generic for all nokia 6630 . when u try to dial from phone book it dosent get called while u try to dial that number from keypad call goes . this is common for 6630 . any way i ahve sold it out thanks god
