Computers & Internet Logo
Anonymous Posted on Dec 31, 2009
Connecting a laptop to a tv
I am trying to connect a Toshiba laptop to a Philips HDTV. I have connected the hdmi cable to both jacks on the laptop and tv, respectively. I have set my tv to Channel HDMI. Nothing happens. I have also tried Channels AV1,2,&3. Nothing happens--nothing appears on the tv screen. Instead, I get an error message stating that the laptop doesn't recognize the USB port. (Are all ports considered USB ports? I DO have a specific USB port on the laptop, but the cable to the tv is going out from a specific HDMI port on the computer.) Any suggestions? Thanks in advance--Chris
  • Anonymous Dec 31, 2009
    Thanks--but no dice. Did FN + F5 and nothing happened.
Anonymous
Level 3:
  • Master 3,153 Answers
  • Posted on Dec 31, 2009
Anonymous
Master
Level 3:
Answers
3153
Questions
Helped
1166256
Points
11010
You have to tell the laptop to use an external display this usually involves pressing the FN + F5 on and acer but does vary from laptop to laptop
the second key usually has two screens printed on it
  • Anonymous Jan 01, 2010
    It may be a different key on yours as I indicated.
    it may also take more than one press to do it.
    You have to keep the FN key pressed in while you hit the second key.
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
3answers
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Connecting laptop to philips hdmi tv
you must have HDMI port on both TV and laptop. you need a HDMI cable to connect to the laptop. but first see that HDMI version of TV is compatible with laptop's HDMI.
2answers
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
I don't know what kind of cable i need to connect my Toshiba satellite L305D laptop to my hdtv
depending on how old you laptop is because the L300 range has been going for a while will be either a HDMI cable or a VGA to HDMI cable but if you require sound and you have to use the latter you will need a headphone jack to auxhilary lead to go from the headphone port of your laptop to the line in on your tv
3helpful
I have a Toshiba Satellite L505D-S5983 Laptop with Windows 7 and a Philips HDTV flat screen TV. I want to run a cable from the laptop to the TV so I can watch online shows on my TV screen. My TV has an...
The price difference in the cables are what type of metal wire that is in it. One might have copper or even gold plated and the lower price one might have some low end metal. I have not seen any difference. Yes, all you have to do is plug it in and Windows 7 will recognize your TV. You might want to go into the Control Panel and open Sounds and make sure you have the audio turned on for your HDMI connection. Your laptop screen and the TV will be displaying the same.
1helpful
2answers
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Grand Canyon Tech
Grand Canyon Tech
