Hi
I have a blown RK46 half watt resistor (faded colors) in the convergence pannel. I cannot read the coded colors. If anyone help me to send the value of it or email the schematic will help me alot. Thanks
Sam
Hi Terryfic
I had replaced the 2.2 ohms one watt ressistor rk46 in the convergence panel of hitachi DX5010B tv. Little better then before except the red is out of wack. Darkloard1 told me to check the filtration capacitor in the horizontal and vertical cct.
I wanted to make sure C615 (25v-2200mfd) is the filtration capacitor if i am wrong please guide me for the right one. The crt. R/B/G can I dicharge 200v by shorting pins p8x1 and p8x2 after shorting these pins I measured the voltage in all three crt. was 0 volt is that enough to work in that area.
2.2 ohm 1 watt...................................T.
Hi
Ihad replaced the rk46 resistor and stk 392-150 ics in the convergence panel of Hitachi 50dx10b. Still there is a very little red and green shadow around the picture. The picture is better than before excexpt it shrink from the sides, top and bottom looks like a cinemascope thing. some one can help me to locate the filtration capacitor in vertical and horizontal cct.. I am not sure about c-615 (25v-2200mfd) if it is not the right one can i get the help on this. Thanks in advance.
Sam
