Troubleshooting and routine maintenance chapter in user's guide
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Download the manuals from:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
and
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_110C_MFC_210C_3240C_3340CN_420CN_5440CN_5840CN_620CN_EN_1266.PDF
Please rate this solution in case you find it helpful, else leave a comment and I shall revert back with more suggestions.
Testimonial: "Thank you for the site info! i looked for a long time, wish i had asked and followed your advice the first thing as it went right to it."
SOURCE: see troubleshooting and routine maintenance
Error 46 in my printer brother DCP-165-C any help please
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
SOURCE: PRINT UNABLE 46 SEE TROUBLE SHOOTING CHAPTER IN
i posted few days back solution to this particular problem, please follow these steps:
first, try to establish if this really is full absorbent pad, remove
power cable from the back, wait 20sec, press menu/set key, insert power
mains - in most brother printer/faxes this will display machine error
code. if this is code 46, you are on the money, your absorbent pad is
full (not necessarily, only counter is showing it as such in most
cases).
we will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
if
that do not work, then maybe really you need to replace absorbent
sponge... it is done under warranty and if not technician in service
centre.
if you want to do it yourself, remove cartridges, remove
fron cover and on the right hand you will have "offending" sponge.
either clean it (absorbent, lint free tissue is fine to remove excess
first, then few drop of water and repeat draining process with tissue
several time, at least till "cake" from the top is removed. best of
course will be to replace the sponge with new one.
after that you still need to reset counter. in another way - follow steps...
if you find this advice useful, pleasae leave comment and rate it, thanx!
SOURCE: unable to clean see troubleshooting and routine
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
