Sony Bravia KDL-52V4100 turns on and displays horizontal bar pattern. Standby light is on and pic off/timer light flashes. Tried leaving it unplugged for 30 minutes but that did not resolve the problem.
Main Power 2 times Power Supply Board G5N Board DC Alert1 3 times BM3 (Main) Board Power Supply Board G5N Board TCON Error 4 times LCD Panel HDMI 5 times BM3 (Main) Board Backlight 6 times LCD Panel Temp 7 times BM3 (Main) Board HFR Error 8 times LCD PanelKDL52V4100:
You can't post conmments that contain an email address.
Sir
PIC OFF/TIMER LED-------Green or Orange LED-------
* Lights up in green when Picture Off is activated
* Lights up in orange when the timer is set
When timer is set, the LED remains lit even
when the TV is turned off
thanks
M Nasir
try some of the solutions on this link hope one will work for you.
http://www.docs.sony.com/release/KDL32S20L1.pdf
look under troubleshooting for no picture
good luck
Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
The red light doesn't flash, it just stays on. The yellow light will go on and off every 10 seconds or so.
