SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
Hey,
Folowing is the link for the service manual for FLU 1911 s :-
http://www.retrevo.com/s/Polaroid-FLU-1911S-TVs-review-manual/id/2894bh033/t/1-2/
I hope it wld help u :)
SOURCE: LG 32'' LCD TV aspect ratio self switching
Not a real solution actually. The store where I purchased the TV changed mine with another one...
Regards,
Massimo Moruzzi
SOURCE: My component cable is not showing any video.
it is a a/v hook up not a component hook up
try that like av1 av2 av3
should work a lot better
ron
SOURCE: Sony KDL-40NX700 has grainy picture on most
Have you checked the cables to the TV make sure they are all tight. Also try bypassing any connections between the receiver and TV.
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
