SOURCE: whirlpool dishwasher model number GU3600XTSY2 is
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
SOURCE: The clean light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
SOURCE: Whirlpool GU2400XTP clean light flashes 7 times.
easy there tiger. at least your machine will tell you what to fix. alot of people on here write in because their machine will run and run and never move the timer. they have no idea that if the water is not hot enough, the timer will not advance to another cycle. confirm the diagnosis with a multimeter and replace the heating element, if needed. checking the connections on the element may be enough. good luck
SOURCE: I have a Whirlpool DU1055XT. The unit will not work
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
SOURCE: My dishwasher ( 66517269400) won't turn on.
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
