What does code sd mean in the spin cycle?
SOURCE: I have a Kenmore Elite Oasis He washer. The washer
sd is suds error. add only HE soap. UL is unbalanced load. watch load size and balancing loads.
SOURCE: Error code SD
This is the "suds" error code. Apparently it means that the machine has detected a high level of suds in the washer, so it temporarilty stalls to let the suds die down. You can fix this by starting the cycle over, and just use less soap in the future. It happens a lot when you are washing towels for some reason...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
