SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
I am having the same problem, i was able to manually get about 37 channels by holding down the BND button which changed the mode to manual tuning which allowed me to manually move to individual stations. By going bak and forth I was able to add more stations, but once I got to channel 38 (which is not a used channel) I could not add more channels. I don't know if this will help you get a few more channels. I am going to try to call clarion to see if they can help, if you get it fixed, please post what you did. Thanks and hopefully we can get this fixed
SOURCE: Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I called Sirius on Sunday. I was still getting the "invld ch" when I tried getting to 184 , but the tech got it hooked up while I was on Channel 1 still, so keep on Sirius. If they say they can't do anything for you, don't let them leave it at that. Good luck all.
SOURCE: Satellite radio (REF) not connecting with Sirius.
how do i use factory satalite antenna on a dodge ram 1500 2006 for after market radio
SOURCE: Starmate reciever (about 6 years old) shows
unhook the power to it for about ten to 15 minutes. hook the power back up and let it "boot" up. that should fix the issue
SOURCE: Why is my signal fading in out on my Sirius
I will advice you talk it to Sirius to help check the service antenna if it has broken, this is most likely the cause or better still if the Sirius star-mate st2 is still under warranty, you let them help replace it, because this is likely to be a panel problem if not service antenna problem.
Take care.
