Ringer Adjustment
How do I adjust the ringer on the base for Uniden DXA15588-2?
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
adjust ringer volume
