GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to replace the door handle. How to I
I am trying to replace the door handle. How to I take apart the door to fix it.
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734553
Points
22413
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, and you haven't purchased a replacement handle yet, the part numbers are WB15X10119 and WB15X10120. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
1helpful
Help fixing a kitchenaid microwave oven/hood combo door handle
The door handles on most appliances, like outside cars & truck handles, are secured with screws from inside the door.
You will need to take the door completely apart to tighten the screws. This may be a very hard job, as it needs to be reassembled as well. God bless your efforts.
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Need to replace handle on GE Spacesaver Microwave J VM130K 004.
I looked up the $39.99 part ! (almost as much as a new microwave)
If you want to replace the handle, get the new handle and see how the new handle goes on and you can determine how to take off the old handle.
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
How to Replace Broken Handle
Sorry but the chat system seems slow and hard to work with.
Page 28 & 29 of the service manual tell you how to remove the door and take it apart to replace the handle.
The service manual is here.
And you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Broken door handle, have part but can't put it on.
Thats disgusting mate! The doors are either clip together, plastics or if stainless as per photo, it would require opening the case, removal of door then prising off the fascia trim to get to the handles.
I'd ring them back up, that is not a user servicable part as it will bugger the finish trying to separate the doort.
Best of luck
Getting door frame apart to install new handle
If you're replacing the handle, then order the choke cover..It's the piece on the inside of the door that covers the handle screws. No matter how carefull you are, it is almost guaranteed to break. If you break it, then you have one, and if not, send it back. DO NOT OPERATE MICRO WITHOUT CHOKE COVER.
2answers
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
