Question about Ovens
Britannia fan oven fan makes rumbling noise when operating. How do you remove fan? What is probable cause of noise? This has just started. Model is Britannia SI-9T.
  • 452 Answers
*****************TURN OVEN OFF AT MAINS OR JUST TURN ALL ELECTRICS OFF ****************NOW.........hi the fan blade nut is anti clock undo... take fan off... you will see three screws undo... go to rear of oven remove panel..... the fan will come away in your hands... disconnect wires ... reverse action needed to put back together....
Posted on Dec 30, 2009
6ya staff
SOURCE:
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Ykemc308kmo oven fan noise
You are probably correct the cooling fan can wear out. You will have to order it by model number. They are a bit tricky to install depending on the oven, but not hard once you get to the fan area. Somke are behing the cabinet and you will have to puul the oven out and some are in the control panel area.
Nov 26, 2013 | KitchenAid "KEBS208sss Electric Double...
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Fan making a rumbling noise
I;m afraid the only real solution here is to replace the offending motor, as this is an indication that the fan bearings are worn and that it will eventually fail altogether.
Mar 29, 2010 | Neff U1452 Double circotherm plus Electric...
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
720 EF Fan oven fan making a scrreching noise now
It could be that cooking residue has run down the inside of the fan cover and it is restricting the fan movement. The fan cover is held on by four self tapping screws, one on each corner. Remove the cover and have a look to see if there are any rub marks on the inside. You should be able to remove some of the gunge by soaking the the whole cover in hot soapy water. If that doesn't work, buy the Lakeland brush on oven cleaner - that definitely works - you can use it on all of the inside of the oven. Whilst the cover is off, briefly turn the oven on to see if the fan still makes the same noise. If it does, it looks like the fan bearings are suspect and a new fan may be required. If not you have found the problem with the cover. Page 37 of the Handbook tells you how to replace the circulating fan.
Sep 23, 2009 | Stoves 720EF Electric Double Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
How to remove a fan/motor from a Zanussi oven
You are probably trying to undo the nut the wrong way.
It is a left hand thread, so to undo it, you go clockwise, as though you were trying to tighten it, and vice versa to tighten it up again. If you can't unscrew the nut, you will have to grip the fan spindle with something whilst you undo the nut.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Zanussi ZHQ575 Electric Double Oven
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Ovens Logo
424 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
