Electrolux EW1000i Front Load Washer Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electrolux front loader wouldn't stop filling.
Machine on standby and started automatically by itself. Started filling and then would not stop. No lights on control panel. Could not start or stop. Turned off power. Water was coming out onto floor. Few minutes later gushed out door. Still no lights on control panel to operate. It is just out of warranty. It is an Electrolux EWF 1090 purchased 19.11.07.
mark warfield
Level 3:
  • Master 453 Answers
  • Posted on Dec 30, 2009
mark warfield
Master
Level 3:
Answers
453
Questions
Helped
150796
Points
1130
Change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Electrolux EWT 604S Front Load Washer. It started intermittently leaking water under machine itself even when not in use. Anyone had the same problem? How did you resolve it?
Why Is My Electrolux Front Load Washer Leaking Water?
Advance Appliance Service https://advanceappliance.com > blog > electrolux-front...
Oct 1, 2020 - A washing machine leaking from the front door usually means the door's gasket isn't functioning properly. When the door is closed, the gasket ...
Missing: ewt ‎ 604s
Washing machine is leaking water
Electrolux UK https://www.electrolux.co.uk > support > laundry > wa...
Jul 15, 2022 - Check if the leak is coming from the tap itself. Check the water supply connection to the inlet hose of the machine.
Missing: ewt ‎ 604s
Electrolux Front Load Washer Leaking Water? ' D & T ...
D&T Appliance Service https://www.dtappliance.com > blog > electrolux-front...
Aug 1, 2021 - If you find your washer leaking from the back it usually indicates an issue with the drain or water inlet hoses. Connection points are common ...
Missing: ewt ‎ 604s
Electrolux Washing Machine - Washer Leaking Water
Repair Clinic https://www.repairclinic.com > RepairHelp > Electrolu...
Here are the most common reasons your Electrolux washing machine is leaking water - and the parts & instructions to fix the problem yourself.
Slip a sheet of newspaper under the bottom of the machine and it will indicate the area. If is does it when the machine is not running. My guess is that it is around the pump because some water always sits there, so either the pump body or the drain hose itself.
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
My washing machine spin drum started making lot of noise and started vibrating a lot.
Not sure why this has happened in a top loader but if its less than a month old call the shop you purchased from , they should still be liable for repair or replacement .any older call the manufacturer for repair.
Simpson drive motor stopped, all other features - fill, drain and rinse working
Hi just read your posting.Now to help you I need the name of your machine which should be on the control panel.Also is it a front or top loader.Looking forward to your reply.
1helpful
3answers
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
I have a 6.5Kg electrolux front loader washing machine it needs a new pump and circuit board... where can i get one of these from????
sorry - no idea - but just mentioning that sometimes pump is blocked by bits of cloth - which is easy to free once you remove pump - this also stops machine continuing normal cycles - i thought mine had problem with the circuitry as it didn't progress automatically but after clearing cloth out of pump it's back to full swing!
2answers
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
