I just finished hooking up my new 220 HUMIDIFIER AND THERE IS NO WATER COMING OUT OF THE DRAIN HOSE AND NONE FLOWING FROM THE INTAKE LINE THERE IS PRESSURE IN THE INTAKE LINE
I have a HE220, HE 260 humidifier..by pass, flow thru. There is no water flow between the hot water tank and the humidifer. The water valve is on. Is there an inexpensive part I can replace myself first before calling a plumbing contractor?
I retraced all the wiring and found that a wire had come apart in the humidistat . I reconnected it and the problem was solved . I would like to thank you for your quick response to my problem Mike
Are you getting 24 volts ac to the solenoid valve?
