SOURCE: NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet
printer 5000 series
The engine test verifies that the print engine
is functioning correctly.
The Formatter PCA is completely bypassed during an
engine test.
This test is very useful for isolating printer problems. The
engine test
prints a full page of lines across the entire printable area,
and is also
useful for checking and adjusting registration.
Note Engine test will print from the last input tray
used.
If the last input tray is empty or if the last input source was the
duplexer,
then the Engine Test will print from Tray 2 (standard 250
CST).
If Tray 2 is empty (and the last input tray is empty or the last input
source
was the duplexer), then the Engine Test will not
function.
Printing an Engine Test HP laserjet printers 5000
series
To print an engine test, use a non-metallic object (such as
a pencil) to
press the engine test button. A single test page with
horizontal lines
will be printed. To print multiple test pages, hold down
the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
SOURCE: Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
SOURCE: pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
