Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome MC 9000 Embroidery/Sewing Machine
My Janome MC 900 has a problem that when I touch the up/down needle button to bring up the bobbin thread, it shuts off. Won't sew another stitch. Have had it at a Janome dealor and he said that he fixed it, but when I got home with it, still same problem. Help!!
What happens and how can I get help?
I bought it new in 2000. The dealer that I bought it from is no longer in business.
  • 2 more comments
  • LadyJ934 Feb 08, 2008
    Can no one of the experts help me with the problem?
  • Anonymous Mar 16, 2014
    janome mc 11000 se bobbin always says it is low even when it is one I just put in that is full
  • Anonymous Mar 24, 2014
    techinical manual
  • Anonymous Mar 25, 2014
    Once the machine finishes sewing the first step in making a buttonhole it sews a straight stitch for the second step but never goes back to do the zigzag stitch on that side of the button hole.
  • Janome Master
  • 1,388 Answers
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Janome MC 9000 Embroidery/Sewing Machine - aaca4c6.jpg
Posted on Feb 16, 2008
6ya staff
SOURCE:
Janome 9000 bobbin thread ends up on top of fabric
change the needle--
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the top thread--top & bobbin
check the bobbin to make sure the bobbin is not damaged
reinsert the bobbin in the case correctly
Jun 03, 2012 | Janome Memory Craft 9000 Computerized...
I am new to this machine & would like to know how to use metallic embroidery thread. Every time I try the thread breaks
check the tension
if the thread will not easily pull thru the needle eye you need one size larger needle
also keep under the needle plate clean of lint
& also the bobbin area
Nov 27, 2010 | Janome Memory Craft 9000 Computerized...
Does this machine have a low shank --- or high shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop
Bargain Box
Apr 19, 2010 | Janome Memory Craft 9000 Computerized...
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
Error; after checking bobbin threads, press start button
This is most probably solved by an adjustment to your bobbin thread sensor, and not something for the home handy fellow......especially without a manual.
Be sure that there is no lint build up in or under the bobbin case as a first measure, and give this area a good clean anyway as normal housekeeping.....this will probably make little difference, but may let you finish any urgent job over the weekend.
When was your machine last serviced ?
2 years or more ?
When was your car last serviced ?
Your best solution is to take it to an authorised Janome Service Centre (make sure they have the Service Manual for this model) and make sure to tell them about the bobbin sensor issue so that it can be specifically targeted during a full service.
This MC 9000 was expensive and the top of the range in it's day and deserves good regular care to work to its optimum for many more years.
Jun 08, 2008 | Janome Memory Craft 9000 Computerized...
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Fabric doesn't Feed
I have a Janome, and when switching from embroidery back to sewing, I must touch a button that electronically moves the mode from embroidery to sewing. In some cases, I've also had to turn off the machine for a few minutes and then turn it on again.
I used to own a Viking - it had a little door covering the attachment link for the embroidery arm. If it wasn't perfectly shut, the machine wouldn't convert to sewing mode, regardless of what button I pushed.
Nov 19, 2006 | Bernina Activa 130
Janome Memory Craft 9000 Computerized Sewing Machine Logo
995 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
