I have a Westinghouse LTV-32w6 HD TV bought in 2006. Almost from the beginning the sound will intermittantly cut out for 3-5 seconds. Sometimes it will be fine for hours, sometimes it will cut out 2-4 times in an hour. It seems to do this whether using straight cable or TIVOed programs or DVDs. Any ideas?
SOURCE: Green screen on Westinghouse tv LTV 32w6
green screen on hdmi is normally a defective hdmi cable. 1st try a different device , like a dvd player. if same problem try dif cable. if it still does not work you have a defective signal pcb otherwise known as a main pcb.
SOURCE: I own a westinghouse LTV-32w6 HD tv. After a year
Try running it with the back open, it can be the LCD controller board is overheat, http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
SOURCE: My Westinghouse LTV-32w6 HD has sound but no picture
You may have problem with the T-C0N board, worst case will be the main logic board, try cooling the T-CON board with electronics freeze spray to see if the problem will go away, you can get it from Radio Shack.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: hi i have a westinghouse Ltv
It can be the main board is bad and not sending the signal to turn on the rest of the power supplies, or the power supply is bad and not supplying the correct voltages to the main board, so you need to inspect the two boards.
Boards for your TV: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV32W6HD+
Please read my guide first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
