RIM BlackBerry? Pearl 8120 Cellular Phone Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you unstick a blackberry trackball? - RIM BlackBerry? Pearl 8120 Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
5900
Points
26
Try this http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html They have some tricks to fix a sticky unscrollable blackberry trackball without disassembling. I try the rotating straw technique and it works for me!! I have my trackball working again now..
Tim Digibrain
Level 3:
  • Master 846 Answers
  • Posted on Jul 19, 2010
Tim Digibrain
Master
Level 3:
Answers
846
Questions
0
Helped
1309852
Points
1356
The only way to fully get it up and running again is physically remove andclean (with alcohol) or replace the part. If you want somebody else to do it for you, goto Blackberry Repair. If you want to do it yourself, here is a Blackberry Repair Guide that shows how, the part is available on Ebay.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2278
Points
5
Please note that the above unique-stuff.co.cc has moved to new .NET domain: http://www.unique-stuff.net/fixing_sticky_blackberry_trackball.html
1 Related Answer
Anonymous
  • 20 Answers
  • Posted on Aug 30, 2009
SOURCE: blackberry 8330 trackball sticking
Your trackball has dirt or more commonly dust in it. You will have to roll it and move it around like crazy to get the dirt out. You can also try blowing while turning.
It is not easy to get it out but when you do it willl work just fine.
My trackball cannot sroll down . its stuckk ..
Hi
To unstick your trackball,you need some rubbing alcohol
Pour a few drops of rubbing alcohol directly on your trackball,you can use a dropper to do this.
Roll the trackball around continuously until it starts to work again
Blackberry bold trackball goes left, right and down but not up how do I fix this?
This is a common problem on Blackberrys with trackballs. When the trackball goes bad you lose one direction first. Inovagent can replace your Blackberry trackball or you can find another local place to have it done.
Feb 07, 2010 • Cell Phones
1helpful
6answers
The ball wont roll on my blackberry. Help!
The trackball is easily removed for cleaning by just pulling the trim ring around the trackball off with your fingernail. Remove the trackball and clean with alcohol. Reverse the process to clean.
Track ball requires multiple press to get it to do anything
Hi, to change the trackball or trackpad sensitivity of the BlackBerry smartphone, complete the following steps:
1) On the Home screen, go to Options > Screen/Keyboard.
2) In the Trackball or Trackpad section, click Horizontal Sensitivity or Vertical Sensitivity to change the sensitivity level.
3) Press the Menu key and select Save. The new sensitivity levels are saved.
A higher sensitivity number indicates a higher sensitivity level for the trackball or trackpad.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in conjunction with a desktop computer.
In the event debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
Try to re-install the BlackBerry Device Software using the application loader tool, before you re-install the software please back up the BlackBerry smartphone data.I hope this information will be helpful to you
Rollerball will not roll upwards??
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
I hope this information will be helpfull.
1helpful
Problem for RIM BlackBerry Bold 9000 Smartphone Track ball does not allow south scrolling; it only allows east, west, north, scrolling. What can I do to fix?
1) Try to re-install the BlackBerry® Device Software using the application loader tool, before you re-install the software please back up the BlackBerry smartphone data.
2) The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in conjunction with a desktop computer. In the event debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem. If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
5helpful
2answers
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Trackball Is Brocken!
Good evening!
Trackballs are VERY easy to replace! You can take it to your cell phone provider but there is a good chance they will claim the phone is broken.
I would recommend searching on Amazon.com, Ebay, or just googling Blackberry Trackball replacement. They are inexpensive, range from $2 to $10 depending where you look and the quality of the trackball.
I personally have replaced my Blackberry's trackball with a new one off of Amazon. It is very easy to replace. You just need to be careful with handling the trackball due to they are very fragile.
Here is a bunch of replacements you can look into on Amazon:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=blackberry+trackball&x=0&y=0
Youtube even has a few videos on replacing the trackball.
Glad to help you out and good luck with your Blackberry!
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
