Hope this helps, keep us updated and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Sound like a malfunctioning
CCD (Charge Coupled Device) image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong
include distorted
images or abnormal colors, scratchy purple lines, blank or black pictures,
and/or black videos with good sound being recorded on the camera's flash
card. I
suggest check this link for additional details in this previous solutions for an Defective
CCD and next contact your Kodak service. Istrongly suggest(taking intoconsiderationthe age of yourcamera) to
evaluatethe cost ofrepairversusthe
cost of anewcamerawith similarfeatures,before making afinaldesicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
First, make sure you have a card installed. Press the Review button, then the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight an option, then press OK.
It is not possible to buy a viewing screen for KODAK cameras. There is no firmmware update available online.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
That will be a mechanical problem and the camera is in a need of a repair.
If your camera is Out of Warranty the repair of this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
NB: You are using the correct battery pack.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
In order to arrange your repair/Trade up: Contact KODAK:
The Z1485 requires 3.7 volts to operate properly. You will not get more than 3 volts with standard AA batteries, and worse yet with NiMH rechargeable batteries which only put out 2.4 volts. You should purchase KLIC-8000 Lithium Ion rechargeable batteries and the special charger.
try removing the framework 2.0 using the .net framework removal tool, just make sure you are only removing the 2.0 , try using this link http://blogs.msdn.com/astebner/attachment/8904493.ashx
reinstall the software afterwards
