TV Engineers in St Augustine FL tells us they can't fix our Westinghouse TV. It is barely 2 years old. They had the TV from Dec. 20 to Jan 28
Where can we bring the TV for repair
the screen is like a big blurr it comes in and out tv is only about 1yr. and 4 or 5 months old.the screen is like a big blurr it comes in and out tv is only about 1yr. and 4 or 5 months old.
AnonymousJul 21, 2008
I have the same problem with a less than 2 year old LTV-37w2. All Westinghouse cares about is if I bought an extended warranty...gee I never thought a $1200. set would break in 2 years. No repair placed in my area will touch the set. So I have one big pile of electronics that don't work. Stick to kitchen appliances Westinghouse. I have the same problem with a less than 2 year old LTV-37w2. All Westinghouse cares about is if I bought an extended warranty...gee I never thought a $1200. set would break in 2 years. No repair placed in my area will touch the set. So I have one big pile of electronics that don't work. Stick to kitchen appliances Westinghouse.
AnonymousJul 25, 2008
The TV will turn off on it's own. I will turn it on and a few minutes later it turns off.The TV will turn off on it's own. I will turn it on and a few minutes later it turns off.
AnonymousApr 26, 2009
We have a westinghouse LCD TV that began to fail just under 2 years old. The color crystals or what ever it's called went hay wire. Colors went darker. Found NO help to repair set. We put up with the problem for 1 year. Sometimes unplugging the set would help because it would reset it's self and would be fine for a short while. Finally nothing helped. It's now a piece of $1,100 JUNK!!! We even had an extended warranty and the place we bought it from went out of business. So much for trying to support the little guys. Couldn't even find another dealer in our area that would touch it. We live in Central Pennsylvania. PS: we're going to Sears to buy a Sony. Westinghouse loss our business. We have a westinghouse LCD TV that began to fail just under 2 years old. The color crystals or what ever it's called went hay wire. Colors went darker. Found NO help to repair set. We put up with the problem for 1 year. Sometimes unplugging the set would help because it would reset it's self and would be fine for a short while. Finally nothing helped. It's now a piece of $1,100 JUNK!!! We even had an extended warranty and the place we bought it from went out of business. So much for trying to support the little guys. Couldn't even find another dealer in our area that would touch it. We live in Central Pennsylvania. PS: we're going to Sears to buy a Sony. Westinghouse loss our business.
Would like to know how to get our set fixed too..looking for a reputable repair outfit in NE Ohio, west. Pa.that can fix our Westinghouse LTV-32w6 TV, thanks. TM
You can't post conmments that contain an email address.
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Doubtful that this can be repaired economically, unless you can do it yourself with glue or some sort of metal band that could be tightened around the brokenb pieces.
4 year old is about the right time for the power supply to fail. That will be the first place to look. Look for bad caps, over heated parts, etc.
See my basic troubleshooting guide and learn about bad caps, failed TV/MONITOR.
Hello, This problem is caused by a bad backlight power supply. Check out this page on our web site: www.ccl-la.com/capacitors.htm If you can solder then you should be able to do the repair yourself.This page gives pictures and parts information. You will need to open your monitor and replace the parts call capacitors that are damaged as directed on the page. If you don't want to do the repair we do offer a repair service for $40 plus shipping.
I hope this helps, if so please rate our solution.
the
