Lexmark P4350 All-In-One InkJet Printer Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Running windows 7 printer wont print anything but installed ok
Level 3:
  • Lexmark Master 6,688 Answers
  • Posted on Dec 29, 2009
Cindy  Wells
Lexmark Master
Level 3:
Answers
6688
Questions
0
Helped
3529973
Points
21744
Is this a brand new computer or did you upgrade to Windows 7? If you did an upgrade, you needed to uninstall the old drivers (with the printer disconnected from the computer). Then you could install Windows 7 and finally install the printer.
You can try unplugging the USB cable, uninstalling the printer and then reinstalling it.
What software are you using to create the file that you want to print? With Microsoft Office, I have seen reports that changing the font on a document can cure a failure to print the document with Word.
I hope this helps.
Printer wont print
Have you connected both ends of the USB cable ?
Check if you have paused printing on the windows spooler ?
Check if the port is correctly configured on the control panel Install Printer using Windows 7
Cx4200 does not print black
If the nozzle test doesn't print black, then no black ink is flowing.
Run a "head clean", and do the nozzle check again.
My printer will not print anything in black,
Can you make copies stand alone in black? If it will make a copy in stand alone then try unistalling the printer and reinstalling the driver.
My printer wont print. I have recently upgraded to windows 7. have downloaded the new driver. but it wont print. i have tried a full reset, partial reset, taking out ink and restarting, putting ink back...
You need to check the hardware functionality of printer first. Make a copy from printer and check if it prints fine. If hardware is okay. You can try following steps on computer.
1- On computer keyboard press Windows(flag) button and R at the same time
2- This will open a small Run window
3- Type devmgmt.msc in Run window and click OK
4- This will open Device Manager window.
5- Right click on psc 2410(2400) entry under "universal serial bus controller" and 'imaging device' and click delete/uninstall/remove. Printer's entry should disappear from there.
6- Disconnect usb cable from printer and computer
7- Wait for 50 seconds.
8- Connect the usb cable to printer and computer.
9- This should install the drivers automatically.
2helpful
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
Installed usb to db26F converter to use printer
Ok reinstall as Administrator, use "Compatibility mode" for install and the run .exe, also run software as Administrator. too. Often these devices, USB - Serial Ports are NO GOOD for a printer. Either install a real Serial Port. or get a new printer. Windows 7 will NOT help either, it doesn't like older equipment.
I just got Windows 7 and just now installed Lexmark X125
Most likely the printer driver on the CD is not compatible with Windows 7. Download the latest printer driver from Lexmark. Click on this link to their WEB site :-
http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
1helpful
I am having problems installing canon iP5200 with Windows 7
Did you upgrade the computer from Windows XP to Windows 7? If so, did you uninstall the driver before you did the upgrade? The old driver files may be causing the problem.
To fix, go to this link, and in the search box in the center of the screen type "windows 7" and click on the Search button. Then select the link "ERROR: Cannot communicate with the printer after upgrading to Windows 7". There will be step-by-step directions for resolving your problem.
My windows 7 won't send anything to my dell 810 printer to be printed. The scanner part of it works but that's it. Why won't it send anything to be printed???
Uninstall the Windows 7 drivers, disconnect the printer, download and install the drivers from Dell's support site and reconnect the printer.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
