Why my phone is very slow .. when i open the menu it takes 3 seconds or more than to open.. and ican't open my appli. manager.. but when the memory is remove i can open it.. please help
Just download one from the net, copy and paste it in your memory card using theUSB data cable, and open it using your phone. It will automatically install the file. No need for other software to have it installed. Also, not all sis files are compatible with the 5233. I suggest you visit ownskin.com if you want free sis files. I find mio akiyama very cute. Hope this helps!! or you could also try this... hi follow these steps
1. Transfer the .sis file to your phone via IR/BT/Cable,(or wap using the wap id).
2. Locate the .sis file using the built in "File Manager" app (in the tools menu),and install the theme to the location of your choice (mmc/phone memory).
3. You can now delete the .sis file.
4. Click on Themes in the main menu,and move left or right to select the memory location you installed the theme to,then select "apply"
Dear customer
You should format your phone
1) Open your memory card from the phone
2) Connect the battery and switch on your handset
3) Dial *#7370# and ok
4) press security code 12345 and ok
It will take a several time and your phone will restart in a few seconds
If your anti-virus and software are downloaded in memory card then format the
memory card in your PC. Thank you for contact.
hey plz help me out of my pendrive... 1)whenever i insert pendrive the error cums please insert disk it gets detect but it shows this error and i cant open
2)second problem m facing dat my pendrive is not showing me in disk management just ican change a drive letter
3)i did everything by changing drive letter also...
Press the Menu Key on your phone, then find Tools. You should find the File Manager. Now through File Manager you can view the files on the Phone Memory and the files on the External Memory.
From there, you can mark the files you want to transfer to the memory card, then press Options and Move. Then just select where you want to move it to.
1. Turn on your computer, and hold down delete. 2. In the BIOS window, look for the Boot Menu option. 3. Choose the QUICK BOOT to turn off memory test .4. Make sure the hard drive comes first in the BOOT ORDER. 5. Turn off any logo displays. 6. Restart
Do 2
1. Open your Start menu. 2. Click Run 3. In the command screen type msconfig 4. In the system configuration utility,click either BOOT tab. 5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button. 2. In the Start Search bar, type control userpasswords2 3. Load the User Accounts window 4. Uncheck User must enter user name passwords... 5. Click Apply
Do 4
1.Click Start button and load the Control Panel 2. Under the Control Panel menu, click Programs. 3. Under the Windows Defender heading choose View currently running programs 4. Choose Startup Programs from the Category option 5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service 1. Click on Start 2. Click Run 3. Type services.msc 4. Select Indexing Service and Double click on it. Select Manual under Startup Type. 5. Click Stop 6. Click OK
hi.. the reason for ur slow operation of ur mobile might be due to some software problem...The only way to get rid of this problem is that to format ur entire mobile...Or the other one may be due to full use of ur memory card...I mean for example if u are using 1 gb memory card u are not suppose to fill ur mobile completely for 1 gb.. try to some keep some memory space which will ease ur mobile opeartion...
It seems your phone is running out of memory. M600i comes with 60 to 80 MBs internal memory. The phone treats larger part of the memory as RAM. And UIQ3 the OS on this phone retains the applications in its RAM once it is opened till you go to Task manager and press exit program. Thus, phone has no other option but to restart to free some memory and show the above message. In your case as you've said the phone restarts after few seconds try this as soon as it starts and home screen appears:-
press (use the jog dial {wheel} and the star key) >*<<*<* (thats:- up*down down*down*) service menu will appear
choose format/restore phone settings whichever applies to your phone enter the security code by default it is (12345). It will format the phone's internal memory which is also used as RAM in M600i. The error message "the phone was restarted to improve performance" appears when there is no more free memory left in the phone's internal memory. Try this and post the result.
