I recently update a pc into windows 7, I´m having troubles using the "belkin wireless g plus mimo usb adapter" to connect to internet, I can´t run the a "driver cure" for windows 7 to solve this out since I don´t have internet access.
Is there any way to save a driver update for my belkin adapter in a windows xp computer, so that I could instal it in my windows 7 pc afterwards?
Thanks!
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Testimonial: "It´s working fine now, thanks!"
This Will work in most Cases Download the Drivers for Vista 64 Bit from www.belkin.com/support Step 1 : Right Click on the EXE File and Click properties Step 2 : Click on the Compatibility tab Step 3 : Select run this program in compatibility mode for Windows Vista SP1 Step 4 : Click Apply Now try installing the Drivers
@Rakesh Warrier I looked on the Belkin website for this model but there is only 32-bit.
