Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Chi Chu
Level 3:
  • Pioneer Master 8,457 Answers
  • Posted on Dec 29, 2009
Chi Chu
Pioneer Master
Level 3:
Answers
8457
Questions
0
Helped
2821040
Points
26282
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Color lines need to be aligned. Color convergence is off
IF THE CUSTOMER CONTROLS DO NOTHING THEN YOU WILL NEED TO MAKE SURE THE CONVERGENCE CIRCUIT IS WORKING. THEN YOU WILL NEED THE SERVICE CODE AND THE ORIGINAL REMOTE AND CONVERGENCE ACCESS CODE TO ALIGN IT.
1helpful
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Convergence board cracked?
Once the board is cracked it is no longer repairable (even if it's a tiny crack that may not appear to interrupt any connections), and you would have to replace the complete board. Any attempt to repair or continue using a cracked board may cause more damage to the entire unit. You can find a replacement digital convergence board for a model # SD-643HD5 from this major Pioneer parts distributor at the following link:
Pioneer SD-643HD5 Replacement Part Digital Convergence Board
Where do i find convergence chips for a pioneer sd-643hd5
Complete convergence assy is available in Part Store for $126
Pioneer Parts has same CONVERGENCE ASSY for $288
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Pioneer sd-533hd5 convergance
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
