EPoX EP-8VTAI Motherboard Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What type and location are the board slots om the EP-8VTAI motherboard. which is PCIe, etc.
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 28, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555090
Points
31058
Any "modern" motherboard will have several "PCI" slots -- usually "white" in colour, and identically shaped.
The motherboard may optionally have one "AGP" slot (for an Advanced Graphics Port video-card), or one, or more, "PCI-E" slots.
The AGP slot will start FURTHER away from the "back" of the computer than the PCI slots.
The AGP and PCI-E slots will be different in shape than the PCI slots, and not lined-up with the PCI slots.
2answers
How to add a card
open the case up then pull a slot out of the case then put it in put screw in card slot then power up then put in drivers for card
tip
PCI slots
<b><span>Most</span> <span>ATX</span></b> <span>motherboards</span> <span>provide</span> <span>at least</span> <span>four PCI</span> <span>slots</span> <span>for</span> <span>expansion</span><span>.</span> <span>Although</span> <span>these</span> <span>standard</span> <span>PCI</span> <span>slots</span> <span>for expansion</span> <span>cards</span> <span>usually</span> <span>available</span><span>, such as sound</span> <span>cards</span> <span>and Ethernet</span> <span>cards</span> <span>are</span> <span>faster</span> <i><span>PCI</span> <span>Express</span></i> <span>(</span><span>PCIe</span><span>)</span> <span>also appear</span> <span>on most</span> <span>boards</span> <span>public</span><span>.</span> <span>PCIe</span> <span>distinguish</span> <span>between them</span><span>, but</span> <span>the number</span> <span>of</span> <span>links</span> <span>or</span> <span>channels</span><span>,</span> <span>they claim</span><span>.</span> <span>For</span> <span>example</span><span>, one</span> <span>PCIe</span> <span>x16</span> <span>offers</span> <span>greater</span> <span>bandwidth of a</span><b> <span>PCIe</span></b> <span>x1</span> <span>slot</span><span>.</span> <span>(</span><span>can</span> <span>only transmit</span> <span>one</span> <span>channel</span> <span>2.5</span> <span>Gbit</span> <span>/</span> <span>s in</span> <span>each</span> <span>direction</span><span>.</span><span>)</span> <span>Therefore,</span> <span>PCIe</span> <span>x16</span> <span>graphics</span> <span>cards</span> <span>use</span> <span>as</span> <span>an Ethernet</span> <span>card</span> <span>can</span> <span>use</span> <span>x1</span><span>.</span> <span>All</span> <span>expansion</span> <span>cards that you</span> <span>use</span><span>, you must</span><span>, be compatible with the specific slot types, of course.</span><span></span>
on Jan 09, 2011 • Computers & Internet
Hi. I have a P8H67 ASUS mother board. it has two PCI 16 Express slots. the first slot is Blue and second slot is black. When I put my 1 GIG DDR2 9500 GT graphic card in the first slot, it gives me 3 beeps...
There are 4 types of expansion slots on this motherboard.
The expansion slots on this motherboard are as follows.
Expansion Slots 1 x PCIe 2.0 x16 (blue)
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI
2helpful
2answers
Wheres the video card located and what does it look like
Hi this will depend on weather you have an separate graphics card rather than an on-board one, if it is on-board you will not be able to replace it as the chip set for the graphics card are on the motherboard and you will have to replace the lot if the graphics have gone u/s, however if you have a PCIe, or an AGP connected graphics card, it should be in the first slot on the motherboard, open up the PC, and you should see the motherboard with lots of chips and a big fan, then you will have some slot's these are either AGP, PCI or PCIe slots, normally the AGP slot is brown in colour, the PCI slots are normally white, and the PCIe slot is normally blue or green, just really depends on the manufacturer of the board, the graphics card will be in the first ( top ) slot, if you have no "addin" cards then everything is on-board, and if its an e-machine, i dare say it will all be on-board...hope this helps
2helpful
2answers
I need help choosing a video card - part 2
PCI is the older, slower format, PCIe is newer and faster, but your system MUST support PCIe or it won't work.
So easy option is to find if your system supports PCIe and then get whichever is suitable.
Video quit...then everything
You computer did not pass the game requirements.
Where does a garphic card fit
Your intel D102GGC2 motherboard has only PCIE slot (black connector- not the memory slot). Its located beside the buttton cell of the mother board. If your graphics card is PCIE, it would directly fit on the black connector.
3answers
EPoX EP-8VTAI HARD DRIVE ISSUE
try creating a volume first in computer management storage section
Top EPoX Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
