SOURCE: high-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
SOURCE: how to create surround effect on cds/dvds which
There is no way to do this in a controlled manner without re-mastering the disc, an unrealistic option.
However, there is a very simple way to extract the out-of-phase portion of a stereo recording, which can yield a quasi-surround sound effect.
To get this effect, connect an additional rear speaker to the positive ( + ) connection of the right speaker output and the negative ( - ) connection of the left speaker output.
Please keep in mind that this only works with a stereophonic (not mono) source and is fairly subtle.
Make sure the speaker you use is at least 8 ohms.
This is an old trick that pre-dates surround sound and works with music CD's too.
This set-up will probably degrade the sound of a true Surround-Sound recording so consider wiring a simple switch to disconnect the additional rear speaker when not in use.
Hope this helps.
Snakeplissken
