Hi; I need to change language from french to english on Bakugan DS game. It's a brand new game and when I put the game in, it's in french but the box and directions are all in english. Is there a way to change the language to english? Thanks for your help :)
Some DS games are only in one language, may it be French, Spanish or English. It's not all games, unfortunately, that have the ability to be multilingual.
In your case, it's a Spanish game which hasn't been translated to English. Therefore, changing the DS's language will have no effect on the game: it'll still be in Spanish whatever you do.
The only way to have the game in English is to have an English version of the game.
When the game start the four items listed as they would read in English are:
-New Game
-Load Game
-Options--------CHOOSE THIS, It's OPTIONS In French
-Credits
The next screen shows(in English)
-Sound Volume
-Music Volume
-Language--------CHOOSE THIS, it's "LAGUE" In French
-Back
From the displayed list of languages select ENGLISH, the select Back to begin playing again.
Due to the larger size of the Pandora's Box game (compared to the Curious Village), there is not enough space on the cartridge to store multiple languages and each version of the game only has one language
This being the case, the French version of the game only has French and you can't select English since the English game data is not on the cartridge
If you want to play the game in English, you'll have to get the English version of the game
You need to create a game and then you will be given to options of: play, arcade, multiplayer, options. Choose options and then language. You should be able to choose from English, French and Spanish. Hope that helps!
remove game chip, turn on DS. from there you can look for a "gear" icon which allows you to change user settings, including language. you change language on the ds itself, not on the game chips.
im not to sure but i will try to help. is the ds in french or just the game, if its just the game. when the game is playing try looking for options then language. or maby there should be a option before the game starts. if its the Ds try remembering where the option screen was. not to sure sorry but they are just my ideas.
Go into game and select one of the saved games if there is one or start a new game. Once Spyro is up and moving around, press start which takes you to the option and at bottom left side there is an option to change language. I did the same mistake and changed language to French, but changed it back to English using above method.
To change the language you must first remove the game chip. Turn on the DS and you will find a "gear" icon which allows you to choose different play options, including language.
I got this from the disney.com/videogames web-site. It works.
1. Put in game and turn on.
2. At Menu tap the bottom listing (Op...)
3. Tap the top listing until English appears. It goes through a bunch of languages.
4. Then hit the arrow on lower left of screen and you are all set.
