SOURCE: format noki 6500
hi
try this code to format the phone: *#7370# ... *#7780# (soft reset) *#7370# (hard reset)
this will help you
SOURCE: I want to formate my phone memory. give me the formating code
A magic word : PLEASE.
In the setting menu scroll down to security then factory settings and choose restore. Or try *#7370#send.
SOURCE: format code for my nokia 6500 slide
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
SOURCE: format code for nokia 6500
Hello thanks for using FixYa
To format your cell
For soft format dial *#7780# or *#7370# which restores the factory settings. it will ask you to confirm that press
OK. it will take some time and your handset will be restored to
original settings.
But if you format the whole phone memory then follow the procedure below
First of all Switch off your phone then press and hold 3 keys combined
then press the power on to switch on the phone.
Note: Remember one things this will deletes all your messages, all contacts,
photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
Default security code for nokia is 12345
See my TRIP & TRICK to format Nokia Handsets which will help you out briefly
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
