I believe there is something wrong with the program memory of your player. This is the reason why its showing program error and any operation that the memory controls would malfunction.
An IC is responsible for this and it needs to be replaced for your player to function well again.
Maybe you should consult a repairer in your area to get the problem fixed.
Take care.
116ER, 117ER, CE2300, CE2350, CE2400, CE280, CE285, CE300, PCR202, PCR204, PCR308, PCR408, PCR350, PCR355, PCR360, PCR365, PCR450, PCR460
This will erase all information - Remove AA batteries and unplug register from wall for 15 minutes.*
If resetting does not work this indicates issue is repair level.
PCRT465, PCR465A, PCRT2000,
This will erase all information - with the PGM key at Off press and hold down the Feed button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros
PCRT470, PCRT480, PCRT48S, PCRT2100, PCRT220S
This will erase all information - with the PGM key at Off press and hold down the Feed (journal) button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros, now press one of the below
22500 Subtotal (PCRT40, 480, 48S)
Or
23000 Subtotal (PCRT2100, 220S )
Wait for a receipt to print.
