Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Jan 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drain Blockage Error
I am getting a drain blockage error message with three loud beeps with interruption of the wash cycle. I am not sure exactly when it is happening in the cycle. It is an intermittant problem that is becoming more frequent. The drain is is in the wall and is not blocked. It is at the height of the top of the washer. Thanks for the anticipated help on this problem.
Anonymous
Level 2:
  • Expert 105 Answers
  • Posted on Jan 28, 2008
Anonymous
Expert
Level 2:
Answers
105
Questions
0
Helped
62862
Points
166
Try cleaning put the pump in the front
the other thing you may have obstruction inside the pipe leading to the pump or away from the pump
coins can get stuck in the pipes and act like a swing valve in the pipe
or your pump may be worn out not pumping water out in programed time
make shure use the right soap powder and dont over suds machine pumps dont pump soap suds
6helpful
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
5helpful
Lg 1815cs error code oe, will not drain, makes wierd noise during cycle
5helpful
Error 03 not draining or going to spin cycle. Tub is full of water. I followed all the steps to drain and clean the hoses, pump, and the pump trap is clear and vanes spin fine. Nothing seems to be...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
2helpful
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Hello! I have an LG frontload washer and it was going fine until a few days ago. It had 14 min left of a cycle and displayed the error message OE. Checked my owners manual and it said that the drain pipe...
3helpful
My lg front load washer stops and give me an error message OE
The front loader for lg washer won't drain
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
