I have a millermatic 200 (black face). Built in 1984 or so. 220v 1 ph power....My problem is when the trigger is pulled, the wire will not feed. I can hear the solinoids clicking but no wire will feed. the feed motor will jump a bit but will not continue to feed. put a volt meter on the wires leading to the motor and it only powers for a second (if that) and then no power. I just replaced the circut board so I know that its not that. There are a few solinoids on this machine could it be one of these?? what about the round blue things ( im not sure what they are). I tapped on one of them and the wire motor rotated, but then I tapped on the solinoid next to that and that also made the wire motor rotate. Im 90% sure my problem is I am not getting continuous power to the wire feed motor. I was told it was most likely the circut board so I sent it out. When they called and said it was bad I figured OK thats the problem. Obviously it was not the only problem, but at least now I know the circut board is good....I bought this welder new in 1984 or 85 and it is used at my home so the usage is mild..
