Our frigidaire gas dryer model LGQ2152ES0 just started making a clicking/tapping/rattling noise in back of the unit. It starts fine, then the noise starts. If you place your finger over the small metal plate on the back of the dryer, you can feel it clicking and the noise stops if you press it. Any thoughts?
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
Gas Dryers may produce buzz when the solenoid opens. The valve clicks at the start of the heat cycle, start of ignition and when the burner turns off. The flame makes a low roaring sound.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru troubleshooting this. It's a different model but the troubleshooting is the same. You can also enter your model 3 for diagrams and illustrations of your specific model.
Prob. some failure of a bracket or loose inside... Have a local tecnician check it out. i think that ll be best cause i can't imagine that will be an easy fix.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
The rattling noise is maybe a sort of buzzing only more metallic? Sounds like the coils on the gas valve making it flutter. Causes are the coils and/or the ignitor. Eric
