GPS Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot connect my samsung phone to garmin gps using bluetooth The phone is a Samsung SGH-T456 and the Garmin GPS is a 265WT. They can sync to each other but the Garmin does not show the answer screen when the cell phone is called and it is not possible to call from the Garmin screen out through the cell phone. If I call the cell phone and press the talk button on the cell phone, then the incoming voice can be heard from the Garmin but talking to the Garmin is not heard on the outside phone.
Anonymous
Level 3:
  • Master 486 Answers
  • Posted on Dec 27, 2009
Anonymous
Master
Level 3:
Answers
486
Questions
0
Helped
154965
Points
1207
There are a few phones that garmins dont work with try software updat from www.garmin.com and samsung, if not that connact garmin and ask if they know of this problem
tip
Nuvi 265WT Change Home Phone Number
Garmin Nuvi 265WT Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 265WT for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Erase Nuvi 265WT Phone Numbers here.
Backup your Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
I wish to erase phone numbers, transferred from my cell phone to my Garmin 265WT when pairing the phone to the Garmin. These phone numbers came from my cell phone and I cannot remember who is associated...
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Garmin Nuvi710 phone book detail does not match phone contacts
I hope that helps.
1helpful
Iwant to know if my 265wt is compatible with my sanyo scp-7050 to activate bluetooth
Strangely, the Garmin web site doesn't list any Sanyo phone in its compatibility list. Don't despair though; the Bluetooth connection protocol is pretty standard (and my Sanyo phone happily communicates with a Bluetooth headset).
Follow the Pairing instructions on pp 14-15 of the owner's manual, which you can download as a PDF file from the Garmin web site. My guess is that it will work just fin.
I have a garmin nuvi 265w and when i connect via bluetooth to my BBerry curve the garmin turns off and on occasionally (usually at a critical point in my trip or during a phone call !). i have the current...
Also, a Nuvi that is turning off and on is symptomatic of having corrupt firmware.
I hope that helps.
Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
Can not use bluetooth with samsung SGH;A501 phone i have a Garmin GPS 660 thanks mark
further to our original problem-we have used our phone with other bluetooth handsfree devices and have no problem with connection-with this gps device the problem we have is the phone connection is linked but there is no audio and then if we use the phone it rings through to the number but when answered there is no audio and then we can't disconnect the phone number
Apr 22, 2008 • GPS
Sync compatible with Garmin?
i will have to check on that for you not to sure
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
