Hi, Look in the floor of the cabinet...there will be two screws that go down into the Microwave...There can be very long... but turn them out and then tilt the oven down in the front and lift it off of the back plate on the wall...
I just removed our Sharp R-1420B microwave. Unplug the microwave. Start by removing the two bolts from the top cabinet (one left and one right). Remove the decorative screws (one left and one right) from the bottom support bracket. I used a plastic bucket sitting on the range as support under the microwave (you may need a couple different sizes). Once the bucket is in place, pull down on the attachment brackets where the decorative bolts were located near the bottom. I used a vise grip to attach and pull them down, and they came down fairly easy. By doing this, the top of the microwave should become detached from the wall. Once you allow the microwave to tilt down far enough (you may need to move the bucket or use a shorter one), you should be able to lift the bottom of the unit off the lower support bracket. Now you can just pull it out from the wall.
Model number is on the side of the control or along he bottom of the frame. The control panel should be removable with a screw or 2 and sliding up to unlatch. the fuse is behind there. To remove it off the wall there is 2 screws coming down from the cabinet above and the unit tips towards you and lifts up off a lip on the back plate. Eric
Probably don't need this anymore, but there is another post, which we added to. Hope you had success.
Be sure to unplug first.
It is mounted on a steel bracket which the micro was tiled into place on. The bracket covers the entire area of the wall where the micro sits.
Basically, two screws in the bottom of the overhead cabinet, and two more screws located in the venting area of the microwave (under). Take the vent filter covers off each side, and remove one screw on each side carefully. If you take the fan cover off in the top front, you can see the steel support on the left.
Two people: The micro is then lifted up and off the support slightly, and then tilt forward to remove.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
