Alpine SWS-1043D Car Subwoofer Logo
googlegoogle Posted on Dec 27, 2009
Wiring diagram i was wondering what the wiring diagram is for this sub
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jan 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
Helped
8273
Points
52
Well for a wiring diagram there isnt one. Really all you need to know is how to wire it properly. You can put it up to 8 ohms and all the way down o 2 ohms and possible 1 ohm. Check this website: http://www.bcae1.com/spkrmlti.htm
I need a 1991 ford explorer fuel system diagram
Go to this site: http://www.bbbind.com/technical.html A huge database of free wiring diagrams.
Click on TSB's and wiring diagrams. Next page, agree to end user license agreement. Next page, click on "Wiring Diagrams", then enter vehicle information in the drop down boxes. Under "system" choose "engine". Under sub-system, choose "fuel controls". Then, click on "search" and you will see 3 results. The last two are engine compartment lay-outs, the first one is the fuel controls wiring diagram. When you click on it, will see all the wiring for fuel controls. When you want to see another system or sub-system, just click on "return to search page".
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Wiring assignment for plug of Panasonic SB WA340
my woofer lost the sound I.C how can i solve this problem?
1helpful
Hi there, my name is adam. I recently bought an alpine typs s 1043d sub (10'') and an alpine mono mrp-m500 amplifier. I was wondering a few things. 1) can u show me a wiring diagram or video or pictures as...
Hello mate,you can do one of two things, you can either google your amp model and download a pdf file of the manual which explains all of what you are asking, or you can email me at [email protected] and i will email you the pdf file, hope this helps you, colin.
2helpful
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
2 ohm sub and 4 ohm sub onto a 2 ohm amp
I presume you are talking about wiring one sub into each out put if so sure you can, but the 2 ohm sub will see more power & it will be louder. If you are wiring them in paralell to one output the load will be too low (1.33 ohms)& could blow your amp ! If you wire them in series to one output you will get a 6om load which will be fine also but with less volume.
How 2 bridge tha opti drive 1222d 12inch subs 2 the opti 600x2hc
You can check Both Crutchfield's learning center on subwoofer wiring diagrams and www.the12volt.com with their wiring diagrams. The crutchfield setup will be more informative for this type of problem. Just go one of the + to one of the - on each sub then wire the other plus's together between the subs as well as the minuses like between the subs and use the open plus and minus that u didn't just bridge. Then there should be just 2 wires a plus and a minus to the amp. Then follow the amp bridge wiring which should be found right above the speaker terminals it will be left plus to right minus or the other way around
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Pioneer HTP-100-SW
i just installed my htp 100 sw. the scheme was atached to the back of the woofer for me tho. easy. front speakers go into the sub in the two botom inputs from the receiver. the two upper are outputs to the actual speakers. hope it helps
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
