I have set the time zone to Paris and the digital time is displaying correctly, however, the analogical time is incorrect. What can I do to resolve this?
Go to the "citzenwatch.com" website
Select "technical support"
You will see "setting instructions", where you must enter details of your watch.
Since they have a "setting "selection, your problem seems to be a common one!
It seems strange that the information you need is not there, since it is likely to be needed at some time in the life all watches when the battery is replaced.
I have a watch which had a similar problem and if it has the same layout, then the lower left hand button scrolls through a number of settings until "HS" is found.
There are two buttons on the right side that step the hands forward or backward. Try this on yours.
Good luck.
Thanks, but I'd already tried that and can't find the answer in the manual! :(
