I am trying to hook up my wii to my LED TV. It does have the component ins, but that is being used by the DVD which is hooked into the U-Verse box. The TV does have another Audio in L&R but no V in. On the side is the HDMI, DVI, USP, PC in, etc. What do I do?
You don't need component cables. Just use the regular AV connector that comes with the Wii and put the video (yellow) in the video spot that is also labeled "VIDEO" and "Y" on the tv...but the red and white (left and right audio) need to go into the farthest red and white connections...DO NOT put them into the ones labeled "Component Pr and Pb." It works perfectly...I just had to figure this out myself.
Couple of options here is a component switch available through Radio shack
http://www.radioshack.com/product/index.jsp?productId=3109731
less expensive versions are available on ebay.
If you have a AV receiver use it to do the switching if it has component in/ outs
If your DVD player has an HDMI output use that to free up an analog component input.
or use a lower resolution input to connect your WII.
Hope that helps
Testimonial: "Thanks I 'll try it."
